2003 Neon battery drain
Old May 1, 2012 | 08:55 PM
Kim Humphrey's Avatar
Kim Humphrey
Default 2003 Neon battery drain
My wife's 2003 Neon just started having a drain on the battery. Using a VOM if checked current draw and found .500ma draw. I pulled fuses until I found the radio/Int light fuse caused it to drop. The dome light is not staying on and there is no glove box light. What else could it be?
I do not have a wiring diagram to trace the wiring.
Any help is appreciated.
Old May 1, 2012 | 09:02 PM
Moparkyle's Avatar
Moparkyle
When you got a .500ma draw was the domelight off?
Old May 1, 2012 | 09:13 PM
Kim Humphrey
Yes the dome light was off. I draws 1.3 amps when the light is on.
Old May 1, 2012 | 10:27 PM
Moparkyle's Avatar
Moparkyle
I don't have a wiring diagram handy but have you tried disconnecting the radio?
Old May 1, 2012 | 11:04 PM
Kim Humphrey
That is my next step tomorrow after work.
