2005 neon sxt noise drivers side
Old May 4, 2012 | 10:28 PM
gator1978's Avatar
gator1978
Question 2005 neon sxt noise drivers side
Hi all, I have noise that sounds like a air leak or exhaust leak when it is in park and starts again at around 2000rpm. When I put it in rev or drive it stops until it gets up to 2000rpm. It is on the drivers side only, louder when listening from the driver side wheel well. It keeps getting louder the more I have to drive it. Any help will be appreciated, thanks
Old May 5, 2012 | 02:41 PM
Moparkyle's Avatar
Moparkyle
Your exhaust runs down the middle of the car until about before the Drivers rear tire then it goes behind that wheel wheel and the muffler stretches all the across the rear bumper..
Climb underneath your car and look for any visible holes in the muffler.
If you are feeling really daring try and get as close to the noise as possible and use your hands to feel (without touching any of the hot exhaust) for rushing air.
Old May 5, 2012 | 05:13 PM
gator1978's Avatar
gator1978
I have checked the exhaust from the manifold to the muffler it is all good. It sounds like it is coming from around the transmission or motor.
Old May 5, 2012 | 05:16 PM
darthroush's Avatar
darthroush
Section Moderator
Is your idle surging at all?
Old May 5, 2012 | 11:06 PM
gator1978's Avatar
gator1978
It idles fine, drives fine, no loss of power that I can tell.
Old Jul 22, 2012 | 12:40 PM
gator1978's Avatar
gator1978
I have just replaced the torque converter, fliter, and oil as sugessted by other mechanics around where i live. I checked the flex plate while i had it apart also for cracks and rubbing. i have more power than before. The blowing/clicking sound is still coming from the transmission area. does any one have any ideas what may be causing this noise?????????
