2005 Dodge Neon problem... stumped
Old May 10, 2012 | 09:17 AM
cavell219's Avatar
cavell219
Default 2005 Dodge Neon problem... stumped
Okay guys last night my girlfriends car was working perfectly no DTC no any lights at all. When she got off work the car would not start. You turn the key starter solenoid kicks in and battery is good. The reason I'm stumped is there a beep noise coming from the instrument panel when you turn the key from run position to on position. 12 loud annoying beeps. Anyone know what this is. I am getting no DTC codes and cannot find any blown fuses.
Please any help before I call the dealer is greatly appreciated. The only thing I found online was about the BCM saying it went bad.... That is very random though....I think it is an alarm feature...
Old May 10, 2012 | 05:06 PM
darthroush's Avatar
darthroush
Section Moderator
Is the red light on in the cluster while you are trying to start it?
Old May 10, 2012 | 07:57 PM
Moparkyle's Avatar
Moparkyle
If the solenoid is actually clicking then I'm assuming it is probably an issue with the starter.
