ABS and traction control lights?
Old May 14, 2012 | 07:09 PM
Moparkyle's Avatar
Moparkyle
You can't connect to any module in the car? Try using both vehicle specific modes and global OBD modes if that fails then try this..
Make sure fuse 21 is good and that you have power present at pin 16 of the Data Link connector and that you have ground on pins 4 and 5.
Old Aug 15, 2012 | 10:05 PM
Jackstep0832's Avatar
Jackstep0832
hey my girlfriends car just got new brakes and rotors...her ABS and Traction control lights were coming on and then her ABS kept grabbing as soon as we starting moving. I looked and sure enough the front driver side tone ring is coming off....it does not appear to be broken and all the teeth seem to be fine.. it appears that it is crooked and about to fall off. its dark out now so i plan on messsing with it tomorrow after work. has this happened to anyone else? and do i need to know anymore then just attempting to push it back on with my hand/rubber mallet?? if that is even possible.
