Power steering leak and clunk Now with Pics
2 Attachment(s)
Hello all,
The car 2003 Neon SXT. She called me and told me she herd a squealing and the a loud clunk on the way home. When I go to her place it was dark so I could not tell what was up. I did notice the power steering fluid was all the way out so I added some and the sequel went away but the fluid quickly leaked out. So most likely a hose has a hole in to, No biggie. But what would the loud clunk she herd be? I know very little about Dodge or even power steering. My auto experience are with jeeps 25+ years old with no power steering:icon_omg:. Thanks alot. O and I forgot to add that there is a big puddle of power steering fluid under the car and its coming from some place but since I have no one to turn the wheel for me so I can look its a real PITA What I did was dry everything and then lay a paper towel under the high pressure hose and the return line on top of the rack, then I turned the wheel back and forth. It was dry. Then I found these two lines on the back of the rack. and wrapped them in paper towel it became wet with power steering fluid, but I could not see any place they were leaking. I'm sure its possible it was running down the lines from some place else but IDk. Any thoughts would be great. Attachment 52824 Attachment 52825 Also it drives fine and dose not seem to have any issues, or even make noise besides when the power steering fluid runs out and it wines like a school girl. |
Looks like your power steering pressure sensor(idle switch) is lose, or the seal is broken... Or maybe the two lines above it.
You know I had even though to look at the sensor, Im not sure why I didnt but the two lines above that I wrapped in paper towel to see if they were leaking did get wet from the bottom. Which is were the sensor is located. Ill check it in the Am. as the car is 20 miles from my house "didnt want to take it on highway: till the issue was fixed.
1 Attachment(s)
Here is a different angle Attachment 52811
I don't see anything I could use to help you.. Have someone get in the car and turn the wheel while you look for a leak...
