2004 dodge neon transmission HELP!!!!
i have a 2004 dodge neon sxt. just had the the trans rebuilt but i wont re learn its settings it will not shift out of second. one of the ecm connectors is loose and does not lock in to place. will the Dodge Neon SRT-4 PCM ECU connector plug terminal harness work on a SXT model or should i change out the ECU.
