engine problems
Old Jul 8, 2012 | 08:50 PM
dodgesrule01's Avatar
dodgesrule01
Default engine problems
i just got a 2000 dodge neon 2.0 sohc put a timing belt and water pump. and when i accelerate between 1000, and 2300 rpm it lugs like its working to hard then. in 5th getting on it at like 70 the check engine light comes. any help would be awsome
Old Jul 8, 2012 | 11:02 PM
Moparkyle's Avatar
Moparkyle
Timing off?
Old Jul 9, 2012 | 07:33 AM
dodgesrule01
No its not and and last night the check engine light stayed on
Old Jul 9, 2012 | 08:16 AM
dodgesrule01
just put the scan tool on it and it says cylinder #2 misfire
Old Jul 9, 2012 | 04:43 PM
jw11432's Avatar
jw11432
make sure cylinder #2 is getting spark. also, if you're unsure of the age of the spark plugs, it never hurts to replace them as a precaution, especially since they're relatively inexpensive and easy to get to. last thing to check is the coil
Old Jul 9, 2012 | 09:19 PM
dodgesrule01
The plugs are new and so are the wires
Old Jul 9, 2012 | 10:42 PM
dodgesrule01
Just put e3 plugs in and it runs like a champ
