How would springs and stock struts mix?
Old Jul 9, 2012 | 07:54 PM
Neonproject12's Avatar
Neonproject12
Default How would springs and stock struts mix?
i was thinking about getting either tien or megan lowering springs and just getting stock struts. Would it be a good mix?
Old Jul 10, 2012 | 12:04 AM
darthroush's Avatar
darthroush
Section Moderator
No. The valving in factory/OEM replacement struts isn't done for the kind of spring rates you'll get in non-OEM springs. Besides, aftermarket struts are cheaper anyways.
Old Jul 10, 2012 | 07:13 PM
Neonproject12
Any ideas where I can go to look at some aftermarket struts?
Old Jul 10, 2012 | 07:42 PM
darthroush's Avatar
darthroush
Section Moderator
goo.gl/V192O
Old Jul 11, 2012 | 11:22 AM
Neonproject12
http://www.modernperformance.com/pro...pension_struts
Are these any good?
Old Jul 12, 2012 | 12:44 AM
darthroush's Avatar
darthroush
Section Moderator
AFAIK, the KYBs will work, but the valving is more OEM than performance. Should still work with aftermarket performance springs, but perhaps, stay with ones that aren't super aggressive.
Old Jul 12, 2012 | 05:59 PM
Neonproject12
Yeah im not trying to go crazy i know they need to be changed but i also want to get lowering springs so i can lower the car a little too.
