Engine Runs rough, out of ideas!
I'm going to try to replace the plugs/wires. Just curious though, what would jumping the car do? It takes a minute to crank if it's been sitting a while, but If it's only a minute it cranks right up.
Does the battery light come on?
If it's, then the battery is weak (it's not holding charge), or the alternator is not charging it.
Easy way to know if the battery is weak, or the alternator has wore out, you jump the car.
If it's not the motor mounts, then I think your car is misfiring (the air/fuel mixture is not ignited).
Misfiring at idle, your car idles rough, causes the engine to shake. You feel vibration.
Misfiring at high rpm, no vibration but your car will hesitate, and no power when you accelerate.
ok- to address all this:
-The engine mounts are fine- I had a friend do that.
-no battery light is on
-replaced battery last week
-the car does this only at 700-800, revving up makes it stop (or makes it so I can't tell)
-the car cranks at normal speed, but when cold takes longer, when hot fires right up. How can I check the fuel pressure
again, guys- Thanks so much. I'm changing the plugs and wires tonight (work got in the way of working on my car!)
Posted from Dodgeforum.com App for Android
[QUOTE=buddhaman;2862856]There's a schrader valve on the fuel rail you can check the pressure with a gauge. yet a can of seafoam and put it through the intake and in the gas tank. it cleans out the carbon and injectors.
Ok- changed the plugs and no luck, still idling rough. I'm going to do seafoam tomorrow on the intake system. I hear it makes a TON of smoke so i'll do it after work at the warehouse location, haha. I'll look up the gas pressure, see if that is it. I'll report back! Thanks again guys!
Not smart to do it near an enclosed space, the smoke is really bad. It'll smoke for a few mins after you crank it up. This is what it'll look like. https://www.youtube.com/watch?v=oMS5...e_gdata_player
I have never heard of someone put sea foam in their gas tanks to clean their fuel systems, but I'm not sure if you can do that. Maybe if you have little gas left in the tank.
There are different products to put in the gas tank.
You put sea foam in the intake manifold through the throttle body, to clean the combustion chamber, ...
If fuel pressure is good, you may want to unplug the fuel injectors to test if they are actually spraying gas. Those products sometime will not help clean out a plugged fuel injector.
How to test the fuel injectors, I hope someone on here can show you a simple way to do it. I can't, I got to go.
