2003 Neon Won't Start-Anti Theft?
Old Oct 15, 2012 | 04:22 PM
GARYSOLDCARS's Avatar
GARYSOLDCARS
Default 2003 Neon Won't Start-Anti Theft?
Went to start my 2003 Dodge Neon (Basic no frills model w/auto trans)and nothing happens. No fuel pump, no turning over nothing, Dash lights come on and yellow light on right is solid.
Checked battery, fuel pump,starter everything is good.
My key is the fat grey key with chip and there is an immobizer which I removed and replaced it looks in good condition with no cracks or breakage.
Called the dealer to see if they could check the key chip but they are telling me that I would have to tow the car to the dealership and then the repair clock would start from there.
UHad a friend who came and used a code reader and no codes show up.
Does this sound like an anti-theft issue and can it be reprogrammed or reset at home.
The car drove like a champ with no issues before this.
Any ideas would be more than welcome.
Gary
Old Oct 15, 2012 | 11:37 PM
darthroush's Avatar
darthroush
Section Moderator
Anti-theft issue would be the red dot staying lit up, and you should still have accessory power and it'll even turn over, IIRC. The car just won't start up and run.
Old Mar 23, 2019 | 05:16 PM
Mussy Jo's Avatar
Mussy Jo
Default How did you resolve your issue
Gary
I have the same issue with my car . How did you fix your issue with the anti theft lock?
Old Mar 26, 2019 | 01:03 AM
paw paw's Avatar
paw paw
Welcome to the second gen Neon forum.
Thump, wiggle, or swap the ASD power relay in the under hood power distribution box with a like one not needed to start or run the engine & let us know how it goes.
Old Feb 8, 2021 | 02:02 PM
Felicia Flores-Lucero's Avatar
mine was a sensor on back of engine. Replaced it n theft went off. I didn't even know it was back there
Old Jun 18, 2024 | 07:34 PM
Neonosiris's Avatar
Neonosiris
Default Engine sensor
Where exactly is this sensor ?
