Parking lights
Old Oct 30, 2012 | 11:06 PM
Neonewbie's Avatar
Neonewbie
Default Parking lights
My passenger side parking light doesn't work.
The signal and flashers work but, the main light doesn't.
Is their two light bulbs in there?
How do I replace them?
Could I use some sort of white light?
Old Nov 1, 2012 | 10:35 AM
cheapez's Avatar
cheapez
There is a neutral/parking switch on the transmission. You can't start the engine if this switch is faulty. Also, I think it will cause the parking light not go go on.
You just need to change the parking light bulb. There should be only one bulb in there. If two, they can't die at the same time. I have seen white lights on the front, but not on the back. You don't want mr.police to stop you for having cool lights.
Old Nov 1, 2012 | 11:31 PM
Neonewbie's Avatar
Neonewbie
i thought it was crazy because, on the one side the flasher / hazards worked but not the main light!!
is a simple plug and play or do i need to remove the headlight
