found solution to steering wheel shake!!
Old Dec 4, 2012 | 03:41 PM
arnonefrank13's Avatar
arnonefrank13
Red face found solution to steering wheel shake!!
ok, so i took off my throttle body and bellow and cleaned them with soapy water and a sock and the dryed them with a diff, sock. then I wiped some of the intake out that i could reach with the sock in the hole. ok also I replaced my battery to ground to the chassis, seemed to have helpd big time. try it if your idle sucks and your steering wheel shakes. my tourque struts are new and align 119mm. but i still have decent tranny and the fender mount. there ok. hope this helps you guys. the back of my throttle body had caked on black stuff.
Old Dec 5, 2012 | 06:04 PM
cheapez's Avatar
cheapez
Clean the throttle body and idle control valve usually help your car idle better, which in turn smooths out lot of things.
My steering vibrates when too much loads on the engine at idle.
Old Dec 7, 2012 | 04:56 PM
arnonefrank13
ya same here... usually only defrost sometimes hi beams too.
