01 neon fog lights
Old Jan 10, 2013 | 11:34 AM
jord712's Avatar
jord712
Default 01 neon fog lights
I have an 01 neon that does not have fog lights, but I am planning to put them in. I have the stock switch with the fog light option and should be getting the lights soon. I am just wondering if there is anything like in-line fuses or relays or anything like that in between the switch and the lights? I'm assuming not and it should be a pretty straight forward job.
Old Jan 10, 2013 | 02:24 PM
TejasMtnBiker's Avatar
TejasMtnBiker
ALWAYS, always put a fuse closest to the power source, not way down the line incase the wire grounds out.
I put those fake Mercedes lookin led's on mine back in 2003 (long before it became oem on most) instead of real fogs
It's never foggy in texas but maybe 1 week out of the year
Old Jan 10, 2013 | 02:43 PM
jord712's Avatar
jord712
Well I'm trying to make everything seem stock so I will be installing the oem switch the iem fog lights and will hooking them up through the fuse block to whichever fog lights go on. So then I wouldn't need an in-line fuse?
Old Jan 10, 2013 | 05:15 PM
darthroush's Avatar
darthroush
Section Moderator
No because you'll have a fuse in the fuse block, which is close to it's power source. Exact same idea, just a different set-up.
Old Jan 11, 2013 | 11:12 AM
jord712's Avatar
jord712
Ok that's kind of what I figured but I just wanted to be safe, thank you for responses. I also am going to plan on converting this car to power windows locks and mirrors, and also hopefully remote keyless entry. I have everything I need except door panels. If any one has a diagram as to where the wires from the rke module connect to that would be great.
Thanks again
