going to switch to synthetic oil
Old Jan 18, 2013 | 01:06 AM
arnonefrank13's Avatar
arnonefrank13
Arrow going to switch to synthetic oil
hello, i'm going to swith to sythetic engine oil. tight now I have super mobile conventinal 5w 30. As for the pre-owners of my 2002 Neon Se, I have no idea what oil(s) were used. What Synthetic oils are you guys runing??
Old Jan 18, 2013 | 08:11 AM
AnthemBassMan's Avatar
AnthemBassMan
-I'm still using Pennzoil Platinum 5w20 in mine. She has just a tick over 130k on her right now.
L8R,
Matt
Old Jan 18, 2013 | 11:27 AM
TejasMtnBiker's Avatar
TejasMtnBiker
I'm running walmarts full synthetic 5/20, then adding 1/2 a quart @ 3k & changing it @ 8k or right when it needs a another 1/2 But I have no change in perf. or mpg when I switched so for the price its cheaper still to run non synthetic with regular change intervals. Soon as it gets to where I need to add more then 1/2 I'll move to 5/30 and see if that cuts down on consumption when parked lol
Old Jan 18, 2013 | 09:07 PM
Moparkyle's Avatar
Moparkyle
I run whatever oil is cheapest in my Neon... And MOBIL 1 5w40 for the Dart.
Old Jan 18, 2013 | 11:44 PM
earlyre's Avatar
earlyre
just wondering WHY you are switching to Synthetic? unless you are wanting to extend your drain intervals up to 7500-10k mi(backed up with UOA's), there is really no need for it in a neon.
Mine has seemed happiest with SOPUS Products,(Quakerstate,Pennzoil, Formula Shell, etc) and a Quakerstate filter (Which like the Mopar Filters are just Purolator Classics with a different paint job) which i can get for $3.02 after tax @ my local Menards, unless they have it on sale cheaper.
Old Jan 19, 2013 | 01:25 AM
arnonefrank13
i like Eric the car guy, BUT Synthetic has a better cold start protection and other things. I'm going to run MOBILE 1 full synthetic 5w 30 and a WIX filter ( I always use wix)
Old Jan 19, 2013 | 03:57 AM
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by arnonefrank13
i like Eric the car guy, BUT thinner viscosity oils have better cold start protection
Fixed it for you
Old Jan 19, 2013 | 09:10 PM
earlyre's Avatar
earlyre
Nothing wrong with wix, have a few in my stash currently.
out of curiosity, how cold does it get where you live?
if you are worried about cold flow, why not 0w30?
that will stay flowable down to like -40.
Advance auto parts has the whole Castrol Edge line (including 0w30 "German Castrol") on BOGO untill the end of Jan.
Old Jan 20, 2013 | 10:42 AM
buddhaman's Avatar
buddhaman
Only reason I switched to synthetic is longer changing intervals. I drive 300+ miles a week and it's cheaper changing it less often. I just use the Wal Marx synthetic.
Old Jan 21, 2013 | 01:23 AM
fhadso's Avatar
fhadso
I use Mobil-1 Advanced Synthetic 5W-20 in my '05. I agree with everyone else on here that it extends the change interval. I am, however going to go the extra mile next month and try out Royal Purple just to see if it's all what it says (allegedly +~5HP). I ran conventional in my '99 Dakota simply because it was older and used the older style of cam/crank (12 valve V6). I also used synthetic in my '00 Neon because it was SOHC. I used synthetic in my mom's '05 Tucson because it states so in the user manual to use (the Hyundai equivalent of) synthetic.
It's a personal preference, honestly. I would use synthetic in 2GN neons, if they have a relatively low mileage (<150K) and a conventional in a higher mileage Neon.
