Heater not blowing any air!!!!
Old Feb 5, 2013 | 06:42 PM
Patsheridan025's Avatar
Patsheridan025
Angry Heater not blowing any air!!!!
As I increase my speed the air begins to come out but hardly any air at all when the **** is in the full position still no air. I just replaced the water pump timing belt,ac belt, alternator belt, and thermostat housing because I thought that would fix the issue but it didn't... Any suggestions I would really appreciate it its cold as hell in ct!!
Old Feb 5, 2013 | 08:24 PM
Moparkyle's Avatar
Moparkyle
Do you mean that there is physically no air moving out of the vents? Because if so it sounds like you have a blower motor issue rather than a heat issue..
Old Feb 11, 2013 | 01:48 AM
arnonefrank13's Avatar
arnonefrank13
check the blower motor fuse then look at clues in the connector. ( mulimeter)
