Intake and rocker arm shafts?
Old Mar 3, 2013 | 01:32 AM
arnonefrank13's Avatar
arnonefrank13
Question Intake and rocker arm shafts?
Does the engine have to be on TDC to just take off the valve cover and swap out both intake and exhuast rockers and shafts?? I wouldn't think so, but need to know for sure before I do the job.
Old Mar 5, 2013 | 06:08 PM
TejasMtnBiker's Avatar
TejasMtnBiker
no but makes it easier is all, esp if you rotate the engine to where both valves are closed when you do each r&r But I'd def measure the shafts with a micrometer or have someone that knows how do it for ya to make sure they are the correct length before just sticking them in with 100% trust
