Constant Volosity shaft or pinoin bearing? Video
Tring to pin point this high pitched howl at 55mph... tell me what you think. I've replaced the driverside half shaft. Soon when the $ is avl. I'll do the passanger side shaft..
Mine has a similar sound, to me its the whine of gears in the diff. Since the fluid is not heavy like a trucks diff lube. I have a real good set of dj headphones on to listen on it a few times. Did it get more quiet after you replaced with a new 1/2 shaft?
