Where is Mass Airflow Sensor located on 2004 dodge neon??
Old Apr 7, 2013 | 06:43 PM
Aymay304's Avatar
Aymay304
Default Where is Mass Airflow Sensor located on 2004 dodge neon??
Changed radiator and took a bunch of other parts off to get to the radiator and now I can not find where the MAF sensor goes!! Need help ASAP!!!
Old Apr 8, 2013 | 12:14 AM
fhadso's Avatar
fhadso
MAF? I don't believe Neons use a MAF. They use a MAP, which goes on the left side of the intake manifold.
Old Apr 8, 2013 | 03:21 AM
darthroush's Avatar
darthroush
Section Moderator
This. Having changed a radiator on a Neon before, I can't think of what part (sensor, especially) you took off that you'd be asking about? The sensors are all attached to different parts. All I recall doing was loosening hoses and the PCM mounting bracket.
Old Apr 8, 2013 | 12:18 PM
Aymay304's Avatar
Aymay304
It's square, has green rubber type gasket in middle . On opposite side of where gasket is, there is a place where a 3 wired connector should connect to. Also has 4 screw holes.
Old Apr 8, 2013 | 12:50 PM
Aymay304's Avatar
Aymay304
It looks like a camshaft position sensor BUT I never removed it
Old Apr 8, 2013 | 03:50 PM
darthroush's Avatar
darthroush
Section Moderator
Sure sounds like the camshaft position sensor...
Old Apr 9, 2013 | 12:14 AM
fhadso's Avatar
fhadso
...Why would you have removed the CPS? It's nowhere near the radiator...
