05 SXT. engine noise
Just looking for sonera pointers. my Neon is making a sputter/tapping sound. I know that on a cold start that it takes a few minutes to go away but its not that, my sound is constant and faster when I accelerate. my mechanic said it may be my belts possibly my pully or tensioner any other possibilities??
If the timing belt has been changed already, I would make sure it's not the serpentine belt tensioner first.
The easy way to do that is to remove both drive belts but, remove one at a time so if the sound is gone you know witch one is doing it.
If you remove both belts and the sound is still there then you know the problem is the timing belt tensioner or something else.
If the sound is not from any of the above then I would check the water pump.
Or if the sound is from the engine try changing the oil with maybe an additive.
