2000 Neon mount replacement
Old Apr 25, 2013 | 12:05 AM
sbhawaiian's Avatar
sbhawaiian
Default 2000 Neon mount replacement
I just replaced engine mount, A.Trans mount, upper, and lower struts. Car runs way better but I still feel vibration at the wheel and shifter when at a stop. I marked the RH side motor mount but there is no adjusting it.
Did I miss anything? Thanks
Old Apr 25, 2013 | 03:02 AM
darthroush's Avatar
darthroush
Section Moderator
If your torque struts were bad any you drove it for awhile, there is a good chance your motor mount has torn and is bad. No adjustment for the motor mount. It is aligned at the factory and needs to remain in that exact spot. Part of the job of replacing that mount is to outline it and put the new one in the exact same position. Stick with a Dodge OEM mount for that one. Aftermarket ones are not fluid filled like the factory ones.
Old Apr 25, 2013 | 11:41 AM
sbhawaiian's Avatar
sbhawaiian
Thanks, the rubber on the DEA mounts did look hard and yes made in China.
