testing MAP sensor
Old Apr 25, 2013 | 04:01 PM
mike L's Avatar
mike L
Default testing MAP sensor
How do you test a map sensor? It's not in my Haynes manual.
I can't find anything under search Map sensor.
2005 neon sxt 2.0
Old Apr 27, 2013 | 12:10 AM
fhadso's Avatar
fhadso
Use a OBD scan tool. You can either spring for one of the $200+ scanners, or just buy a bluetooth OBD scanner from eBay, and then connect to it via an Android or PC to look for the PID.
Also, I think AutoZone has a scanner that can read the MAP, and either they can do it for you, or you can rent the tool.
Old Apr 27, 2013 | 05:21 AM
darthroush's Avatar
darthroush
Section Moderator
Give this a try and see what happens: http://easyautodiagnostics.com/chrys...shooting_1.php
Old Apr 27, 2013 | 12:45 PM
Moparkyle's Avatar
Moparkyle
I've never personally seen a map sensor fail. You should be able to monitor a PID with a scan tool.
