Problems with Camshaft Pos Sensor
Old May 19, 2013 | 10:04 PM
spoonmectr's Avatar
spoonmectr
Default Problems with Camshaft Pos Sensor
Hey folks,
So I have done quite a bit of searching and haven't found any help yet. I have a 03 Neon SXT. Runs perfectly except sometimes it has a hard time starting. Pulled the codes and it has P0340 and P0344. So I replaced the Camshaft Position Sensor and cleared the codes. Immediately after I started it up with the new sensor it pulls a P0016. Car runs perfectly, just can't get rid of that code. I thought I got a bad sensor so I put the old one back on and erased the codes again. Started it up and the 0016 code was gone. Shut the car off and tried to restart and it wouldn't start again. So I went and got another sensor from a different auto parts store. Cleared the codes and put it on and as soon as I started it back up again I got P0016. Again the car runs fine but I cannot seem to figure out why this is happening. Anyone have a theory?
Old May 21, 2013 | 04:14 AM
xarkhun's Avatar
xarkhun
i dont know if this helps but here is a link to the obd2 code site for code 0016
http://www.obd-codes.com/p0016
hopefully this will shed some light on what may be the problem
