p0456 and p0455
Old May 30, 2013 | 09:27 AM
jamesneon2003's Avatar
jamesneon2003
Smile p0456 and p0455
hi there . I have this code p0456
I went and changed every hose down by the canister
went bought a evap canister,gas cap, the purge solenoid was replaced along with leak detective pump. that was done at the shop..
I changed the hoses and evp canister..
well the engine light was gone then 3 days later it came back with a different code. the code is p0455
p0456 is gone but code p0455 is on now..did I miss something ..any ideas
Old May 31, 2013 | 12:13 AM
Ryan 20's Avatar
Ryan 20
Check the over flow pipe that comes off the filler neck for damage.
Also check for any cracked vacuum hoses in the engine compartment.
