help
Old Jun 19, 2013 | 06:25 PM
tschay's Avatar
tschay
Question help
help please i dont know what it could be? i will try to explain. the car runs fine. when i get to where im going,once i turned the key to shut off the engine i forgot to put the car in park and took the key out . buy luck i was in the car when it rolled. i dont think it should be that way. so what do u think it could be please let me know
thanx, tschay
Old Jun 20, 2013 | 04:21 AM
darthroush's Avatar
darthroush
Section Moderator
Bad/worn ignition cylinder lock.
Old Jun 20, 2013 | 10:40 PM
tschay's Avatar
tschay
but the key wont come out with the car running. the lock cyclinder is less than a year old. so what do u think
Old Jun 21, 2013 | 02:06 AM
darthroush's Avatar
darthroush
Section Moderator
Is your shifter cable and bushings in good condition? Perhaps something there is worn or out of spec that is allowing you to do that. Can't think of anything else besides those two things.
Old Jun 21, 2013 | 04:42 PM
tschay's Avatar
tschay
Smile
thanx ill look into it further, if u think of anything else to check let me know
btw,i dont know if it makes a difference but it is automatic trans. thanx tschay
