Wheel alignement adjustment cam bolt??
Old Jul 4, 2013 | 10:06 PM
DevinPistol's Avatar
DevinPistol
Exclamation Wheel alignement adjustment cam bolt??
Hey everybody, im new to this thread but it thought it was the best place to check, So the previous owner who owned my car decided itd be a good idea to try and drift the car and smack the curb, Needless to say ive replaced the whole front end steering system *******ly, and then i got to the back and noticed i had some mad posi, camber. and thats not good, so i looked and my lower control arm was bent. so i tryed to get the bolt out didnt work ended up cutting the bolt off, first mistake, the bolt i bought at partsource was the wrong bolt. so now i need to know where to find this bolt and how much. i have searched almost everywhere, and when i type it into google or look on websites, i get two smaller bolts. but not the big one im searching for. Any help would be greatly apprecaited. Its number 7
Attached Thumbnails Wheel alignement adjustment cam bolt??-20130704_200444.jpg
Old Jul 5, 2013 | 02:02 PM
xarkhun's Avatar
xarkhun
i did a search for lateral arm bolt and it looks like you can get it form dodge for about $13.60 looking at the schematic on there sight its the bolt your looking for
http://www.factorychryslerparts.com/...roduct=4500125 hopefully this link works its #21
Old Jul 5, 2013 | 03:39 PM
darthroush's Avatar
darthroush
Section Moderator
The Dodge parts manual lists it differently. The bolt (#21 in the Dodge diagram, as xarkhun points out) that goes with the nut (#7) lists as:
06502796 SCREW, Hex Head, M12x1.75x242
The actual nut (#7) lists as:
04626993 CAM, Rear suspension
The two lateral arms (control arms) list as:
LINK, Rear Lateral
04656358AA Right
04656359AA Left
Knowing what places charge for the lateral arms, a junkyard might be a better option.
Old Jul 5, 2013 | 10:13 PM
DevinPistol
First off thank you all for all the help its really apprecaited, Next question is the bolt just a standard bolt? because i work right beside a nut and bolt place and can pick up the bolt for cheep, and all id have to worrie about is the cam adjuster
Old Jul 6, 2013 | 02:42 PM
darthroush's Avatar
darthroush
Section Moderator
The bolt is likely just a higher grade, standard bolt.
Old Jul 6, 2013 | 09:20 PM
DevinPistol
Okay awesome guys thank you, Last question, does the camber adjuster bolt have a little tab that sticks off of it?
Old Jul 7, 2013 | 04:58 AM
darthroush's Avatar
darthroush
Section Moderator
On the rear? IIRC, the bolt is just a bolt, but the nut/"adjustment cam" (I'm assuming that's what the nut is called?) should be eccentric and allow the adjustment. That's how I remember it anyways.
