Engine mount question
Old Jul 29, 2013 | 04:46 PM
TuhGrr's Avatar
TuhGrr
Default Engine mount question
asdaasdasdasda
Old Jul 29, 2013 | 09:23 PM
earlyre's Avatar
earlyre
i think the torque struts have to come off, and the engine tilted up off the motor mount. the diffrence between the OE part, and the aftermarket, like the one you've linked to, is the OE is a fluid filled mount, while the aftermarket units aren't. the difference being vibration dampening.
Old Jul 31, 2013 | 05:42 AM
darthroush's Avatar
darthroush
Section Moderator
What you have linked is the engine mount. That's the part that you should optimally get the OEM part. The Anchor will work, but you'll likely have vibrations in the car afterwards.
Old Jul 31, 2013 | 05:12 PM
TuhGrr's Avatar
TuhGrr
Old Jul 31, 2013 | 08:01 PM
richards83's Avatar
richards83
Yes, he will have to remove all three. If the torque struts are in good shape, I would re-use them. IMHO the OEM torque struts are superior to the cheap aftermarket ones. I've been disappointed my those Anchor mounts so many times, I won't use them anymore.
Old Aug 13, 2013 | 02:59 AM
TuhGrr's Avatar
TuhGrr
