Won't start after transmission swap
Old Aug 1, 2013 | 01:09 AM
booktaz.rs's Avatar
booktaz.rs
Unhappy Won't start after transmission swap
This is going to be very very vague. 2005 Dodge Neon sxt automatic transmission; bought another (crossing fingers) same year. swapped it out and hopefully all connection are correct. But now won't start not even a click. All electronics turn on, I need ideas as to what might be the problem, what could i have over looked or need to check again. Very frustrated.
Off topic where can I send someone to see the installation of a transmission install so they know what they are doing? or an idea of what to expect. Thank you for looking and I hope someone can give some very needed help
Old Aug 1, 2013 | 08:52 AM
Welcome to DF! I will move this to the Neon section.
Old Aug 1, 2013 | 03:00 PM
richards83's Avatar
richards83
I recently swapped out the trans in my Neon. Seems like it would have to be something involved in the trans swap. I would go back and double check eveything you did. Could be the battery ground behind one of the bellhousing bolts or the wires on the starter.
Old Aug 1, 2013 | 05:50 PM
booktaz.rs's Avatar
booktaz.rs
Thank you will try to double check every thing without dropping the tranny.
