2005 engine compression test
Old Sep 29, 2013 | 01:23 PM
dodge_neon_man's Avatar
dodge_neon_man
Default 2005 engine compression test
i was just wanting to know what my engine compression test should be. i know how to do it but just not sure what the commpression should be for each cylinder. i have 2005 dodge neon 2.0 thank you
Old Sep 29, 2013 | 03:54 PM
Welcome to DF. Post your question in the Neon section. This section is for reporting issues with the Dodge Forum internet site.
Old Sep 29, 2013 | 05:31 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Moved the thread for you.
Compression will vary based on mileage, valve wear, piston ring condition, Ect.
Normally each cylinder should be within a certain percent of each other. With that being said, a service manual will tell you complete specifications on what they should be and what percent within one another. Low compression or big differences between each will mean a rebuild
Old Oct 1, 2013 | 01:33 AM
JoseyWales's Avatar
JoseyWales
the min compression no less the 125 psi.. and no less then 10-15 percent per each cylinder differance from each other..but seen 20 percent but that didnt affect the motor much....my wife has three cars.. 2 neon and a breeze..her first gen neon has 170 psi in all accept #1 has 160..that has 181000...2 gen neon 2 170psi and 2 155 psi and that has 142000..breeze has all 175 psi accept 1 was at 160...that has 157000 on it...now my 01 neon has 2 200 psi and 2 190 psi in the cylinders..that has 103000 on it..
