Automatic trans wont shift in reverse, no drive
I have a 2004 dodge neon that was giving me some issues after a long road trip. I stopped off after about 300 miles. On decel it started shaking badly and in first and reverse would thud and shake violently. I got it towed home and the problem still happened. I replaced my CAS and the problem got much better and saw I had a blown bottom pass. side motor mount. After driving it for a couple days with no issues except much less problematic reverse, the gear is completely gone now. Drive also went away. I removed the trans relay and I get drive back but with no OD. Is the trans completely gone or do I have something to work with? Thanks
