03 gauges in a 01
Old Oct 6, 2005 | 01:12 AM
neonperformance's Avatar
neonperformance
Default 03 gauges in a 01
hey all i hav a 01 neon es with a rectangle connector in the middle of the dash for my guage cluster. i want to know if a 03 guage cluster will connect woth my harness? and work properly please HELP thanx
Old Oct 6, 2005 | 02:42 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: 03 gauges in a 01
I'm fairly certain they do. My 04 has a connector just as you described.
Old Jul 18, 2006 | 02:25 PM
Gomer_Canada's Avatar
Gomer_Canada
Hey there Guys n Gals, I just picked up an 04 Cluster for my 01 Neon. Has anyone made a How to Do for this or shall I? From what I can tell so far this is going to be a very easy swap.
Gomer
Old Jul 18, 2006 | 10:29 PM
Gomer_Canada
Okay here is what I have learned so far.
1> the console comes apart very easily.
2> do not try to remove the needles for the gauges as they will break.
Here is my "HOW TO" for the disassebmly of the new console to insert the old odometer... u know to keep it legal.
Step one.. looking at the front of the gauge cluster remove all the screws holding the cluster together.
[IMG]local://upfiles/39901/3BEC8E9DD48A46A6AC498A4D09FF4DEA.jpg[/IMG]
Remove the clear plastic cover...
[IMG]local://upfiles/39901/65D75725CE0240CC8A76366DB3D5151D.jpg[/IMG]
Step two.. remove the screws holding the cardboard to the back of the console.
carful not to break the front trip meter button.
[IMG]local://upfiles/39901/46767FA617E84F658BF36F02CD555DA1.jpg[/IMG]
Step Three.. gently apply pressure to the 4 pin posts that are sticking out for all the gauges while holding the console by the white plastic only. Work your way back and forth between the console gauge posts from left to right or right to left until the front seperates from the back.
[IMG]local://upfiles/39901/741128FDBE7A4CD6B78E2B374D3E63E1.jpg[/IMG]
Step Four.. remove the two screws holding the odometer to the front of the console.
[IMG]local://upfiles/39901/52786266F70A4A23A9DD00E4E9EBA6FC.jpg[/IMG]
Step Five... install old odometer... This is the plan for tomorrow night. Where i will pick this up and let you
know if the mileage reading is correct.
Gomer
Old Jul 19, 2006 | 11:17 AM
Gomer_Canada
Okay, I haven't figured out the problem just yet but either the new cluster has a problem or its the swap of the odometer. I will have to tear it apart tonight and take a look. Basically the odometer is just blinking at me... with two f's and my running lights are not on along with the background display light on the console is very dim. Hopefully putting the 04 odometer back in will fix the issues.
Gomer
Old Jul 19, 2006 | 11:21 AM
Gomer_Canada
Default How to Swap your Console!
Hey neonperformance, can you change the name of this thread? Mabey make it "How to Swap your Console!" Or I will just make a new one. Let me know.
Also the 03 guages will definatly work in an 01.
Gomer
