ignition key comes out at any position
Old Dec 2, 2013 | 08:39 PM
jaye944's Avatar
jaye944
Default ignition key comes out at any position
as per the title, I found that the ignition key comes out at any position, the car can be started and turned off.
One good thing is I can start my car and remove the keys to warm it up
However, I tried my spare key and the same thing happens, when I put a DIFFERENT key for example the caravan, the key goes in and and only turns one position but can't turn back, I can put the real key in and turn it back.
So looking I think I can work out how to replace the cylinder, does it just need cleaning, repair or is it worn? If I get another cylinder, is it easy to re-key myself
any ideas on prices?
thanks
OH I'm assuming its the cylinder and NOT the lock inside?
Old Dec 3, 2013 | 10:52 PM
JoseyWales's Avatar
JoseyWales
thanks
dont worry about replacing it..all 3 of our neons do that too..1 first gen and 2 second gens..even my farther inlaw 01 saturn does that too..think its cool..
Old Dec 4, 2013 | 07:48 AM
TejasMtnBiker's Avatar
TejasMtnBiker
yea its fun to replace... NOT Just lube it an keep on truckin
Old Dec 4, 2013 | 07:41 PM
Neonewbie's Avatar
Neonewbie
That sucks I hoped to chime in and tell you to have a new key made.
I had a worn key for one of my cars and did the same, warmed it up and took the key out lol.
Just dont leave your car unlock, having a worn ignition will make it easy for someone to steal it :P
Old Jan 3, 2014 | 12:30 PM
TejasMtnBiker
these days who'd steal our neons
Old Jan 3, 2014 | 02:51 PM
jaye944's Avatar
jaye944
thanks guy's
however I've found another side effect of this..
(already posted another question which is related)
When I turn the key to off, then pull it as I usually would, the radio (RBK CD)
doesnt seem to be fully powered of !
So you get the time, and it stays on, even when opening the door, and returning, say in an hour, this resukted (after 2 days) of a dead battery,
I also pulled the IOD fuse (radio) and this seems to have done the trick... no extra draw to flatten battery
So I think the cylinder other than being worn is also not fully switching the accesories off when you pull the key out in that position
I also now cant push back the IOD fuse. DOH
