power steering
Old Dec 28, 2013 | 10:56 PM
rowdy1919's Avatar
rowdy1919
Default power steering
i have a 2002 dodge neon and the power steering fluid is always leaking. the leaks are in the front of the car. do i need a new power steering pump. it is very hard to turn and there is never any fluid where the you put the power steering fluid at. help please!!!!
Old Jan 3, 2014 | 12:39 PM
TejasMtnBiker's Avatar
TejasMtnBiker
couple places to check, return rubber lines to the reservoir can have cracks, lines to rack an pinion, pressure sensor on rack & pinion can be leaking as well. Most are easy fixes
Old Jan 3, 2014 | 11:02 PM
earlyre's Avatar
earlyre
and don't use power steering fluid. these cars use ATF+4 in the power steering system.
