'05 Neon SXT front wheel bearings
Old Dec 30, 2013 | 04:39 PM
shlbydaytona89's Avatar
shlbydaytona89
Default '05 Neon SXT front wheel bearings
I have an '05 SXT. I need to replace the front wheel bearings. I know some newer Dodges have front bearings that unbolt and pull away from the spindle, instead of being pressed in. Are the FRONT bearings pressed in or do they bolt in? Does anyone have a DEFINITE answer, not a guess?? thanks guys..
Old Dec 31, 2013 | 06:04 PM
AnthemBassMan's Avatar
AnthemBassMan
-They are pressed in bearings. You can either buy a new bearing and press out old/press in new, or you can also get a replacement hub assembly that has the bearing in it.
L8R,
Matt
