2002 Neon transmission trouble
Old Jan 22, 2014 | 03:24 PM
lesk's Avatar
lesk
Default 2002 Neon transmission trouble
Hi there, I have had a rough time with my 4-speed auto transmission in my recently acquired '02 Neon. Here's what's wrong:
*When put in drive, it doesn't go into gear right away
*Abnormal shifting at highway speeds
*Hard downshift from 2nd to 1st gear
*Leaking fluid (quite a large amount)
I have looked on this forum for a similar problem/solution, but couldn't quite find any. Here's what I have done:
*Replaced trans. pan (with new gasket)
*Replaced trans. filter
My apologies ahead of time for a possible re-post, but any insight at all is greatly appreciated!
Old Jan 22, 2014 | 04:08 PM
richards83's Avatar
richards83
Your symptoms sound like low fluid level. Have you checked for fault codes? Some atx codes won't come up when you do the key dance thing. You'll need a code scanner for that. I know it's probably a stupid question, but you did use ATF+4 fluid right?
Old Jan 22, 2014 | 05:38 PM
lesk's Avatar
lesk
I recently checked my fluid levels, and they were actually a tad bit over full. I do use only ATF+4, so I don't think that's a concern. I have also checked for codes, but I don't know if the scanners at Autozone can check for those specific to the transmission.
