Surging at 40-60 mph
Old Jan 30, 2014 | 09:01 PM
Motoatrix13's Avatar
Motoatrix13
Default Surging at 40-60 mph
Ok, so I have a couple of issues I cannot figure out. First, when running between 40 and 60 miles per hour the car will surge when given light throttle. It will also sometimes sputter and come close to dying, when I take off. The sputter is intermittent though. The car seems to be ok if I drop it into 2nd gear, but as soon as I up up shift to 3rd, it starts again when I apply light throttle pressure. I have replaced all the plugs, plug wires, alternator, battery, coil pack, cam positioning sensor, and crankshaft positioning sensor. I am getting no check engine light or codes.
So, could it be the fuel filter/pressure regulator? The car revs fine in park and idles pretty good. I am at a loss and really have no idea where to start. If anyone can help me, I would be greatly appreciated. I am hoping I can fix it myself and not have to take it into the shop. Thanks in advance for any info I get.
Old Jan 31, 2014 | 10:37 AM
srt4rez's Avatar
srt4rez
I would check all vacuum connections, sometimes leaking vacuum lines can cause a problem like that. Check wires as well, make sure no shortening around the engine compartment. Make sure spark plugs are gauged properly too. You might want to add a good gas additive to clean out your system. Also make sure your check engine light works.
Old Jan 31, 2014 | 02:34 PM
bgii_2000's Avatar
bgii_2000
Wink Check for shortening
That definitely seems like a fuel system / engine sensor problem. Either the ECU thinks that the engine needs more gas, or the fuel system is giving if more than it needs. Vacuum is definitely a good place to start.
The CEL will generally only throw the code if it does it more than once in a certain time period. See if you can trigger the symptoms several times in a row (like 6 or 7 repetitions). Though, you might not get any more than just a Cylinder # Misfire detected code.
