comp. code(torque conv.) question
Old Oct 11, 2005 | 06:45 AM
phearly's Avatar
phearly
Default comp. code(torque conv.) question
Hi,
My 2001 plymouth Neon(automatic trans.) has had a check engine light on ever since I got it(used). I had the code pulled & reset @ Autozone & it came up up with a torque converter circuit code. Does anyone know what would normally cause this code? The car seems to drive ok except sometimes it seems like you have to push the gas pedal in seemingly farther than you should to get it to accelerate at a decent rate. So in an emergency situation where you might need quick acceleration I think you would be screwed!!! But this may be normal for all I know since this is the 1st Neon that I have ever driven. Can anyone give me any tips/suggestions/ideas?? I have to get the car inspected(live in DE) next year & I hear that if there is check engine light/code present they will fail the car for the inspection. Thanks in advance.
BTW....after the code was reset it came back again a couple miles down the road.
