Broken Hub Studs
Old Oct 12, 2005 | 05:34 PM
AlfFan013's Avatar
AlfFan013
Default Broken Hub Studs
I was driving in my 03 Neon and i hit a nasty pothole with my 17 inch rims and the damage wasnt what i wanted to see. I bent both of my right side rims and one tire was cut and on top of that 4 of my right rear hub studs broke, i was curious if anyone could tell me what i should do to replace these, should i buy a new hub, take the hub apart and replace the studs or what?
Old Oct 12, 2005 | 06:21 PM
casper's Avatar
casper
Default RE: Broken Hub Studs
IF you broke 4 studs, that was one real nasty pot-hole. You can get them at autozone for like 99 cents a piece. just hammer the old ones out and then hammer the new ones in. I would check for more damage though, that sounds like you hit pretty hard.
Old Oct 13, 2005 | 04:54 AM
olagunas's Avatar
olagunas
YOu will want to have the alignment cheked.
Old Oct 14, 2005 | 07:53 AM
casper's Avatar
casper
ORIGINAL: olagunas
Sorry, I thought that was a god spoken given after a pot hole like that, but you are right, lol
Old Oct 15, 2005 | 02:40 AM
AlfFan013's Avatar
AlfFan013
Im also having some problems removing the drum so i can get to the bolts whats an easy way to remove it???
Old Oct 15, 2005 | 03:35 AM
casper's Avatar
casper
ORIGINAL: AlfFan013
Honestlly get a little ruff with it and use a hammer, your not gonna break the drum.
Old Oct 16, 2005 | 02:36 AM
y2neones's Avatar
y2neones
yeah, a rubber mallet works too. you have to beat the hell out of it.
