2004 SX 2.0 starting issue
Old Mar 28, 2014 | 09:32 AM
squrtle's Avatar
squrtle
Default 2004 SX 2.0 starting issue
I have need of direction on what to do next, it starts with a lot of cranking ( 5 or 6 tries and 30 sec of cranking )maybe, i have changed crank sensor, cam sensor, timing belt water pump, spark plugs and wires, ignition coil, new battery, and at wits end with my little car, no codes no warning lights, I turn key on hear pump start and stop crank and it is a coin toss if it starts, if it does not its like it is flooded i some times smell fuel, 100000 miles on her
Old Apr 1, 2014 | 02:03 PM
TejasMtnBiker's Avatar
TejasMtnBiker
any cel codes? do you hear fuel pump pressuring up when you first turn the key to on?
Old Apr 2, 2014 | 06:53 AM
squrtle's Avatar
squrtle
No codes and you can hear the pump pressure up when key first turned on
Old Apr 3, 2014 | 05:39 AM
73novass's Avatar
73novass
go back to basics check compression that's what it sounds like then spark then put a gauge on the fuel rail and see what you psi is I am not sure what it is supposed to be call dodge or maybe somebody here knows
