Can anyone tell me how to remove my top speed limiter on my 05 neon?
At this point the only way to do it cheap, is to put a toggle switch inbetweeen the PCM and the spedo sensor. You can just disconnect it, but it will cause some problems with the PCM. Just put the switch in and when you wanna go fast, hit the switch and your spedometer will goto zero and you will be able to go as fast as you wanna go. The better option, if you have the money is to put a fuel and igniotion system in, thats gonna cost you though, $1000- $1500 at least.
