courtesy lights
Old Jan 31, 2015 | 09:33 PM
whatyourbeef's Avatar
whatyourbeef
Default courtesy lights
I want to put some courtesy lights in my neon. I want them to come on with my dome light. So I'm wondering where could I splice into. Any info is appreciated. Thanks!
Old Feb 1, 2015 | 01:00 AM
darthroush's Avatar
darthroush
Section Moderator
Where are you planning on installing the courtesy lights?
Old Feb 1, 2015 | 02:01 AM
whatyourbeef
Under the dash, to light up where your feet sit.
Old Feb 1, 2015 | 09:36 AM
Tie into the dome light circuit. Usually the wires run up the a-pillars to the dome light. Grab a chiltons or Haynes manual with wiring diagrams to find which wires to use.
Old Feb 2, 2015 | 08:12 PM
darthroush's Avatar
darthroush
Section Moderator
I want to say the dome light wires go down the left side c-pillars on the Neons. You might try wiring something up in the dome light switch circuit. I think under the driver's kick panel, there is a yellow (ground) and pink (positive) wire for the dome light circuit.
