P1299 Code after replacing starter
Old Feb 8, 2016 | 08:07 PM
jaybaron's Avatar
jaybaron
Default P1299 Code after replacing starter
So I replaced my stater because it died and it looked simple enough to change myself, I am a car repair novice but I want to learn, but after I replaced it my my engine revved uncontrollably. Thankfully I was able to get an engine code out of it though.
P1299 (M) Vacuum Leak Found (IAC Fully Seated) MAP Sensor signal does not correlate to Thorttle Position
Sensor signal. Possible vacuum leak
I don't think it's a vacuum leak because to get at the starter comfortably I moved the air intake box which has the cruise control lines connected to it, which I'm guessing messed upped the throttle on the engine and now they are miss matched. What do I do now? How do I re-calibrate or reset the throttle so they match?
