upper & lower
Old May 12, 2016 | 07:03 PM
TejasMtnBiker's Avatar
TejasMtnBiker
Default upper & lower
can this cause a slight pull to the right and left @ speed 50+ if they are bad?
Old May 30, 2016 | 03:08 PM
darthroush's Avatar
darthroush
Section Moderator
Upper and lower...engine mounts? No. Ball joints (though there is just a lower on the Neon)? Yes.
Old Jun 1, 2016 | 11:59 AM
TejasMtnBiker
upper/lower torque strut mounts are bad but never imagined that would cause this
Ive either got bad axles & or wheel bearings, @ 65mph under light acceleration it will steering walk to the left but when jacked up nothing is loose.
Old Jun 4, 2016 | 02:09 PM
darthroush's Avatar
darthroush
Section Moderator
Could be either I suppose, though I'd lean more heavily to a bad wheel bearing over a bad CV shaft causing an issue.
Old Jun 12, 2016 | 01:36 PM
frenchyfab's Avatar
frenchyfab
alignment?
