biggest tires on 2002 neon se
Old Apr 12, 2004 | 02:54 AM
2002neonjc's Avatar
2002neonjc
Default biggest tires on 2002 neon se
Right now I have 18560R15 tires on my neon.
What is the biggest size tire that can be put on the rim?
Mine are pretty much worn out and I will be replacing all four but would like to know if I can go any wider than what i've got now.
Thanks
Old Apr 12, 2004 | 07:31 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: biggest tires on 2002 neon se
Yes you can go wider, I did on my R/T. I put on a set of Bridgestone Potenza RE950's size 195/60/15. Check out Tire Rack for more info on plus sizing and maybe figuring exactly how wide you can go on it.[sm=smiley2.gif]
Old Oct 18, 2006 | 07:41 AM
vansterdam's Avatar
vansterdam
Here's a website to calculate tire sizes
Once you change the width, you will need to change the aspect ratio to keep close to stock tire height.
Old Oct 20, 2006 | 12:37 AM
02neonse's Avatar
02neonse
dont know about the tires, but i got the same neon have you done anything to it?
