Headlight problems
Old Nov 15, 2005 | 01:25 PM
TropicalStarz's Avatar
TropicalStarz
Default Headlight problems
I have had xenon blue headlights in my 2000 neon for about 5 months. The driver side headlight went dim yesterday and took longer than the other headlight to turn off. I went and bought new headlights and put them in and they worked fine.. this morning I turned my lights on and it was dim again. Could this be an electrical problem? If anyone else has had this problem, I need some tips on what to do. Thanks.
Old Nov 15, 2005 | 07:23 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Headlight problems
What wattage bulbs did you put in there? Or if you don't know the wattage, what bulbs specifically did you put in there. I've heard of damage being done in some cases where higher wattage bulbs were installed without upgrading the wiring harness.
