adjusting timing tensioner
Old Sep 7, 2017 | 08:05 PM
mike L's Avatar
mike L
Default adjusting timing tensioner
When your tighten the timing tensioner do you always turn until it doesn't turn anymore? How loose should the belt be after install, I can move it less then a 1/4".
Old Sep 8, 2017 | 01:41 AM
darthroush's Avatar
darthroush
Section Moderator
You're answer should be in the shop manual.
Old Sep 8, 2017 | 07:59 AM
mike L's Avatar
mike L
It says to align the spring tang and setting notch. I think I went a little further then that because I heard a pop ( I coundn't tighten any more) and removed my 1/4" ratchet from the tensioner and the tensioner didn't loosen. I tighten the center nut. I turned the timing belt by hand 4 times. There's no noise from the tensioner. Did I go to far, has anyone else set it this way?
