03 Neon SE- Hard downshift from 2-1 (Auto)
Old Jan 21, 2018 | 11:04 PM
BroHymn85's Avatar
BroHymn85
Default 03 Neon SE- Hard downshift from 2-1 (Auto)
Hi folks, 03 Neon with just over 90k miles just developed another annoyance. Now, while in Drive and coming down from 3rd & 4th gear it's slipping/clunking from 2nd to 1st at 20-25 mph. This does not occur coming from 3rd to 1st or 2nd to 1st. Also, driving shifted down to 3rd stops the problem. My guess is it could be the solenoid again (replaced several years ago) or low on fluid. It looked low and I added some but the problem is still happening. Any thoughts?
Old Jan 31, 2018 | 10:22 PM
paw paw's Avatar
paw paw
Has the filter & fluid ever been changed?
Old Jan 31, 2018 | 10:43 PM
paw paw's Avatar
paw paw
Has the tranny filter & fluid ever been changed?
Old Feb 13, 2018 | 12:41 AM
BroHymn85's Avatar
BroHymn85
Yes indeed, a few years ago, full flush, new filter and gasket.
Old Feb 13, 2018 | 01:50 AM
paw paw's Avatar
paw paw
Ok that's good feedback, so it's had a full fluid flush & filter change, so not likely a gum, varnish, sludge problem, if the old fluid wasn't degraded at the service time..
A tranny is a closed loop system, so doesn't consume fluid like a engine, so any idea why the fluid came to be low? If it was low enough for the tranny pump so suck air, that could cause mischief, as the pump won't like trying to pressurize aerated fluid nor will the solenoids like trying to control things with aerated fluid. If we think of aerated fluid as a spring, rather than a solid, trying to move things in a pressurized hydraulic system, then we can visualize how aerated fluid could corrupt its action.
