Excessive oil on cam position sensor
Hi gentleman , how much oil is expected normally to leak out from the cam seal and into the cam position sensor area, Im throwing an intermitant code for cam sensor
there is a seal on the cam sensor , where does the excess oil go ? also how huge a job is it to replace that cam seal, all i see info for is the front seal at the belt end . there must be a cam seal on the position sensor end of the cam. thanks gentleman , Bob
Welcome to the 2nd Gen Neon forum.
I don't know the answer to your cam sensor replacement. Might be helpful to know the year/model vehicle you have. You can go here https://dodgeforum.com/forum/2nd-gen...ml#post3259651 & select a link for the year FSM = Field Service Manual for your vehicle. Then log in Here & Google to view or download the FSM, or part of it your interested in. Let us know how it goes.
