Neon Radiator/ tranny issue!!!
Old Dec 2, 2005 | 12:36 AM
sxvipers's Avatar
sxvipers
Default Neon Radiator/ tranny issue!!!
I just had my 2001 neon spit out the tranny cooler fitting in the radiator on the pressure side. Come to find out from my Radiator Repair Shop says that all 2000 to 2005 neons will and i and i mean WILL blow the fitting out of the bottom tank of the rad. The Repair shop told me that Chrysler will not do anything about this and that when they do fix them, They don't even use there own rad because they know that there rads will do this. I put a spectrum rad back in that had brass fitting that won't blow out. If the car is driven at all after the hose and fitting blows out of the rad, it will dump all the tranny fluid on the ground and burn up the tranny.
Replacement Rad Spectra #CU2363
