01 neon flywheel wont turn after tranny swap.
Old Jun 19, 2018 | 01:05 PM
Richard Barber's Avatar
Richard Barber
Default 01 neon flywheel wont turn after tranny swap.
So I'm having a problem with my 01 Neon it's got the 3-speed transmission which burn up on me so I pulled it out swapped it for a new one new torque converter as far as I could tell the torque converter went into place a spun it and got the two clicks and everything bolted up just fine motor right up against the transmission but now the flywheel won't turn everyone seems to think that it's because my torque converter wasn't seated properly but my theory is if the torque converter wasn't seated properly then they shouldn't have bolt it up right there should be no room for the motor to bolt up to the tranny problem is I also have two broken motor mounts and I'm wondering if that could cause a binding somewhere.
Last edited by Richard Barber; Jun 19, 2018 at 01:06 PM. Reason: Miss spelled after lol
