2005 neon hose beneath/connected to IAC valve
Old Oct 19, 2018 | 11:38 AM
Chester Mealer Jr's Avatar
Chester Mealer Jr
Default 2005 neon hose beneath/connected to IAC valve
I noticed the hose beneath/connected to my iac valve has deteriorated. Which is probably the cause of idle issues with my car. However, I can't find a part number or name to look for a replacement. I've seen where it connects and it looks like something I can do myself if I can just find the right part. If you can tell me what look for I'd appreciate it.
Old Oct 19, 2018 | 11:49 AM
A pick would help. Is it a rubber line? Take it to an auto parts store and match the size up to some rubber hoses they have. Usually buy it by the foot.
Old Oct 19, 2018 | 12:04 PM
Chester Mealer Jr
it actually breaks just a few inches past what you can see in the picture but this was the best way of identifying it
Old Oct 21, 2018 | 09:10 PM
Chester Mealer Jr
bump? I did post a pic if that helps I don't know if it's a generic rubber line or not is the problem.
Old Oct 21, 2018 | 09:35 PM
Stop by an auto parts store and see if they can source the part or offer an alternative.
Old Oct 23, 2018 | 02:55 PM
Chester Mealer Jr
I got the two pieces off and went by both autozones in town. The old tubing is thin and quite stiff, they said all they had was the soft tubing and that it might be a problem. Is that true?
And am I correct in thinking that the black part beneath the IAC valve is part of the throttle body?
Old Oct 26, 2018 | 09:32 PM
davethepear's Avatar
davethepear
I used oil resistant hose, like for a trans cooler. mine was split too, lots of vacuum leak. yeah, it's the throttle body.
Old Oct 26, 2018 | 10:30 PM
Chester Mealer Jr
after the stupid dealer parts guy told me the wrong part (it's not a crankcase breather hose). some more digging found that the pipe it connects to goes to the purge solenoid. The pipe is apparently part of the vapor harness.
I was able to find one at a junk yard, but good to know the oil resistant hose works if it happens again. Thanks for the response
